question
Rick_From_Mi
ok when my engine revs up it sounds like air is either being sucked or pushed thru the front part of the throttle body where the spring is. is there some type of o ring or seal that could be cracked. thanks
-rick
aint SYTY's fun? myne is...
Rick_From_Mi
the vacum line is fine. i still think its comin form where the spring is for the throttle body. i will call al dustin later to see if he can give me any adivice what it could be before i tear it apart.
Thanks
-Rick
warmpancakes
leaking throttle shaft very common get a can of carb cleaner and spray around the area if the engine revs you found your leak. ken
