summit makes an aluminum rad that is for the s10 v8 swap. it has brackets and all. two row. and the description says that the stock shroud will fit with some modifications.
i think im just gonna measure my s10 for the 31x19 and see if i can make some brackets. since i don't have a lower intercooler radiator.
1-800-radiator
I got one for my 96 ext cab 4x4 silverado from there,and it was only $265 shipped to me in about 3 days,and it was over $400 at all the local auto stores.
Another good place for a stock replacement is www.radiatorbarn.com. 133.90 with free shipping and a lifetime warranty. Make sure you order the one with the internal oil cooler unless you plan on using a separate one. The Summit radiator listed above shows it is for a 4 cyl truck, not a 4.3 and probably does not have the oil cooler.
WHEW, I thought the radiator would be more. I just got into an accident and need to replace it...sorry for bumping an older thread, but I need these links ---
