Rear Drive-shaft
1BADSUV
I am trying to track down a vibration on my Typhoon and had the truck up on a lift and my mechanic told me my rear drive-shaft is bent. When on the lift, we put the truck in drive and he put a screwdriver edge on the shaft and you could tell it was vibrating. Is that enough to put the AWD system out of balance? Can anyone recommend an alternative rear drive-shaft? I did run a search and did not come up with much.
Thank's
2cold
Check locally for a shop that builds driveshafts and they could make you a new one or try the dealer or Dustan Racing becuase I believe Al makes an replacement for the stock one that is better.
