Rear Suspension mods
BigBadSmoosh
Re: Rear Suspension mods
mattw said:
You could always try a diet.. I'm sure a little less weight in the cab would help the issue. Probably be cheaper than constantly buying new suspension parts as well...
-Matt
i don't sit over the rear wheels, but thanks for the suggestion.. ass :squint:
warmpancakes
Not as bad as you would think I have about 1500.00 into mine but thats all chrome moly, and the best heim joints,
BigBadSmoosh
I have no doubt in my mind I could build one with the help of a college roommate for cost in materials alone, its just a matter of time (homecoming is a month away) and $..
The syclone might eventually get some nice suspension mods, but i like to keep my ty running, as best as possible anyway.
turbodog
warmpancakes said:
cough 4-link-cough
I would like to do this someday, for improved handling.... but, I don't understand how it solves the problem of lowering the truck 2.5 - 3 inches and not having it bouncing off the bump stops. Just rising rate coilover springs?
warmpancakes
well the bump stops are gone, including the bracket but a real stiff spring takes care of that
Loeryder
Stiffer springs = less suspension travel maybe?
Or while you are in there welding all the 4 link you do a mild c notch to accommodate the lowered stance.
I wish I had the resources to 4 link my Ty.
Daron
warmpancakes said:
the cladding will hit before a c-notch is needed on these trucks
Yes, its true. Tires and cladding will hit.
I have a triangulated 4 link Jeffery made for me, on my Sy. I like so far. Havent done a good launch with it yet but it corners and rides very well. Very big improvement over leafs, and I have the truck pretty low.
Yes in general. Most of the front coilover kits already have reduced suspension travel.
mattw
Coil springs work better with reduced suspension travel because they offer a progressive spring rate. The further the suspension gets pushed up the more it resists. Leaf springs basically have a flat spring rate.
-Matt
Houseofperformance
switchhappy!!!
suicidedoors has a great reputation for shure. are you going to install the kit? you will need a fuel cell to run it cause it interfers with the gas tank i think - don´t forget the c-notch to lay some decent sparks ;-)
I realy wonder how much power it can take and how it acts handling wise.
