Road tracking caused by directional tires?
I just talked to the guy at Tire rack who told me going to a narrower tire will not help my cause, trying to eliminate the tracking my truck does on the grooves in the road. He said it is not caused by the width but by the angle of the tread. Anyone know if this is true?
sy#2921
BAMF
Re: Road tracking caused by directional tires?
hows your alignment? Personally I just got mine does yesterday after 3 years of owning the truck, man was it bad. Now it dries like a dream even with 275 DR's up front
Alignment checks out. Also the alignment guy told me my front end was very solid. I had asked him to spend a pinch more time looking for problems. Things are definitely better but I never had this issue until I put my Z06 wheels on. If a front wheel were bent would it cause this maybe?
LIL QIK
HELL YEA I GOT BOOST!
Mike....isn't your truck lowered. If I'm not mistaken the Baer Trackers will help get the geometry back into check.
Yeah but its been lowered waaay before I put the Z06 wheels on. OK, so what the hell are bear trackers? I just searched and it seems they are a brand or model of tie rod?
LIL QIK
Well I think that's all it really is...except with a little more adjustability. Baer's site gives a pretty good description of them. But Warmpancakes could probably offer some insight being that he's actually installed his. Mine are still sitting with the rest of the parts waiting for me to get home...lol. I just ordered them because I also have the 295's on the front and anticipate problems with the bump steer. Anytime I've ever gone to a wider tire than factory and lowered the vehicle...I've always had problems with the vehicle wanting to follow the cracks in the road surface. And typically gets really bad if it hits some unlevelness as well.
So it appears Baer trackers are just adapter for heim joints for tie rods ends. Its similiar to what Dunstan was doing with his Tierods. Basically the Heim have no giving to them, so thier is no play in the tie rods. I have a set of Dunstan Tierods.
As for 275's I put on a set of 275's ZR-1 wheel (from my Corvette) on Typhoon with a rebuilt front suspension (and tie rods ends), it followed the road grooves like crazy. My 86 Corvette didn't have this problem at all. 86 Corvette came with 255 from the factory, I noticed a slight increase in tracking when I went to 275. One note is that GM change the suspension geometry (Zero Scrub) in 1988 on the Corvette when it went to 275 tires.
Someone around here mention that increased caster helped with the tire tracking issue. it would be great if someone could figured out what need to be done to keeping the tracking down to a minimum.
In my Syclone, I stuck with my stock wheels and tires, because I was so turned off by the tracking. Soemtimes, I wonder if I would have tracking issues since my suspension is now a full coilover, the steering is redone with heim joints, and I have quite a bit of caster in my alignment.
warmpancakes
the bear trackers help alot as the put some "slop" in the tie rode to allow the wheel to move some before the steering wheel, they dont make them for a 4x4 so i made the 2wd work
What did you have to do to make them work?
I am working on it. I will order these trackers next week more than likely along with a different pair of tires for the front. I plan on a whole different size for the front altogether. We'll see what happens.
jpalmer
In my Syclone, I stuck with my stock wheels and tires, because I was so turned off by the tracking. Soemtimes, I wonder if I would have tracking issues since my suspension is now a full coilover, the steering is redone with heim joints, and I have quite a bit of caster in my alignment.[/QUOTE]
how do you like the heim steering im wanting to do that when my front wears out
jpalmer said:
dgoodhue said:
In my Syclone, I stuck with my stock wheels and tires, because I was so turned off by the tracking. Sometimes, I wonder if I would have tracking issues since my suspension is now a full coilover, the steering is redone with heim joints, and I have quite a bit of caster in my alignment.
I am not quite sure I did everything at once. JS Coilovers, Heim Joint Tie Rods, ZQ8, new idler arm, pitman arm, Renz's shaft. I have driven other trucks with coilovers (and not Heims) and they feel alot like mine.
jpalmer
thanks
2kwik4u
Resident slow guy
My 2wd has a ton of tracking as well. More caster is the answer. Throw the stock specs out the window, do a search for the specs that Jeff Scott posted awhile back. Get as much caster as you can, and keep both sides equal and it will track nice and true regardless of road surface or tire width. I have over 5* in each side on my 2wd and run 275's up front with ~5" of drop aside from some serious steering wheel slop, it tracks nice and true.
Tires are going to be my first try. I need new fronts anyway. When I get the tires on I will probably search for a different alignment spec. Wont hurt to try something new. If all else fails I can have them put it back. I may try raising my truck back to stock just to see if it still does it to rule out the Baer Trackers.
2kwik4u
Resident slow guy
Caster. Someone suggested "get as much caster as you can" in your alignment. I don't know what the max caster attainable for our trucks is, but "all you can" is probably too much. Once again research the term until you understand what it means and does. Caster is the difference the top ball joint is ahead of (positive) or behind (negative) the lower ball joint. The spindle is roughly half way between them, lined up on the direct line between them. When the wheels are turned, the tip of the spindle turns down-ward in an arc, thus lifting the vehicle. The weight of the car makes the spindle want to return to the 'centered' position. The problem with "as much caster as possible" is that it makes the vehicle tough to drive. It takes a lot of effort to turn the steering wheel, especially at low speeds, because the turning is lifting the weight of the truck.
I know exactly what it does and how it effects the drive ability of the truck. I think I've probably researched it more than anyone ever should.
Low speed effort is increased, slightly. We have power steering on these trucks, and thats typically a ton easier to deal with than the truck moving sideways at freeway speeds because of it tracking through grooves in the pavement. It's all a compromise, and I'll take a little extra effort any day.
While it might be the tires, it might be the steering box, and it might be the tie rod ends.......all anyone here is doing is posting what has worked for them. I've seen more than 10 trucks with suspension all the way from stock to full coilover benefit from more caster. Throw as much as you can in there, then start backing it down until the steering effort, and road tracking are at acceptable levels. I've found 5-7* to be about as much as you can get in the front end of a 4wd s-series, as well as a good compromise between the two conditions.
My experience with Typhoons and my 85 Corvette (85s have conventional, not "zero-scrub", knuckle design) is that 3° positive caster is just about 'right'. Good trade-off between driveability, and on-center tracking. I once requested "more caster" at alignment time to reduce wander in the Vette. The shop put in 7°!!
I was able to put in 3.25 degrees of caster in my suspension (I did my own alignment). It was the maximum caster I could attain on both sides (one side I was able to get 3.5 degrees) The factory spec for SyTy is 1.5 degrees of caster.
