rpm delete belt size?
MikeSyclone
just curious what the correct belt size is for the rpm ac delete kit....i got mine and i cant seem to get it around the tensioner
Black Knight
I Glow Therefore I am
Re: rpm delete belt size?
Mine was really tight also, after talking to Mike about it he said sometimes you need to heat them up first also. I just through it in the oven for a little bit and then the other trick is to put the tensioner on first and slide the belt over the water pump while someone holds the tensioner. It's so tight that it's almost impossible to get over the tensioner, but the water pump side allows for it to side on.
MikeSyclone
yea the one i have is 85.5, i tried to heat it up in the oven, still no go, are there any other tricks/tips
91blazins10
The one they sent me said it was 85.5 when you typed the part # in a search but really it was 85in.
