Spectator DragR
Truck quit on me yesterday while cruising down the road. Pulled the coil wire from the cap, turned key on and I got a spark, turned key to crank and got another spark. There was only that one spark when first trying to crank. Pulled the distributor and found the pickup coil retainer broken. Was wedged in there making the dist shaft difficult to rotate. Pickup coil checked good. Put a new retainer on it. Everything rotated smoothly. Started it up and it was barely running, popping out the exhaust... like it was running on only 1 or 2 cylinders. When it quit smoke came from the air filter. I unplugged the brown "timing wire" under the dash (like when setting the timing) and it started up and ran smooth. Had to drive it home that way. Turned it off at home, plugged up the timing wire and it does the same crazy thing.
What do you think?
What do you think?
