3/8" drive works ok too but, it is a tight fit... When messing around on the back of the motor I like to jack the rear of the truck as high off the ground as I can. I chock both front wheels for safety, BTW. Makes reaching everything much easier. Don't forget to disconnect your ESC (tan wire with black stripe under heater box) when you set the timing. HTH's
