Slow resurrection of '93 #1003
TheBEAVR
After being busy the past few weeks I finally got some of the kinks worked out to get this thing up and running again.
It started out looking like this
I removed the tint, slapped on new tires, and put it back to stock ride height.
I took the HVAC box out since the old one had cracks all over and was about to fall apart.
New box with a fresh coat of paint on it.
Between the 8' long Taylor wires and this ziptie being used as a wire separator, I'm not sure which is the funniest.
I put new plugs, wires, cap, and rotor on it. Then wrapped the downpipe to help keep temps down in the engine bay.
The old plugs came out with .045" gap. I put the new ones in with .028" I give props to the person who put in UR55 plugs. I was expecting to find some Bosh platinums or E3's with all of the other stuff I found.
Some people will believe anything that they see on TV.
Junk
All of the U-bolts snapped as I was taking them off.
Some people should be allowed to own nice things.
Driver side PCV tube open to the atmosphere. Another awesome tie down job.
Who needs this??? lol
The engine bay being put back together in a much neater fashion.
I have no idea what the people/person who installed this were thinking but it wasn't a good thought. I kept having issues with the AC not cooling much at all and when cruising down the highway it would run 210 with the AC on. I never really paid attention to this but Erik pointed it out at the Texas meet. I took the front of the truck off and found this. The hose from the intercooler pump, pumped water to this and then went back to the upper inter cooler. Both water connections at the bottom created an awesome air trap inside this thing which negated its purpose.
Here are some after polishing photos.
Re: Slow resurrection of '93 #1003
Nice job!
I swear SyTy = zipties
I must have cut three dozen zips off of mine the first day I had it..
atkonkler
Is this your bush?
Keep in mind when wrapping the turbo what an oil leak will do when its soaking in that wrap! It equals a fire/ carbeque! Owie, owie, owie!
TheBEAVR
That's what the slow leak from the intercooler is for and here I thought you were a Red Green fan. :lol:
asmo
Sy #2918
Did you put the some type of downpipe shield on it, never seen one before, looks like a great idea.
TheBEAVR
This was on it when I got it. I removed it and repainted it with some high temp paint. I would assume that they put on on from factory since all of the GNs had them.
TheBEAVR
Double Intercooler! Almost like a double rainbow but not quite. :) Thanks, Erik, for pointing this out.
Someone needs kicked square in the nuts.
TheBEAVR
The paint is still trash but looks a lot better with some wet sanding and polish. I think I'm going to yank everything and have Maaco spray a singe stage on it and work it out to make it look good.
Before
After
Before
After
Before
After
Before
After
Sean Krupa
Moderator
Nice job! We used to use the same Compound at the Body shop I used to work at. Awesome stuff. Did you use a Buffer or by hand? Also is that your Gota have it Green Mustang?
TheBEAVR
It is great. I like the 3M stuff. I did the majority of it with a buffer. There were a few spots that I had to get by hand, like the indentations in the hood and down the sides of the truck.
Yes. It's a '13 Boss 302.
killa66cam
RIDIN DIRTY
Nice work, especially on the buffing. I need to get mine buffed, then it wouldn't look so terrible!
Cam
TheBEAVR
0966Sy
Code what?
Looking good brandon! The paint should last if you keep it waxed to prevent it from fading. Just let me know if you got some questions about anything under the hood. Looks like you got the paint covered.
TheBEAVR
I took possession of my dash about a month ago and decided I should go ahead and install it. When I took it out I never thought I would find what I did.
The previous owners were right when they said this truck wasn't neglected. It was raped. If this Typhon could talk it would ask to trade its life for that of a middle eastern woman.
We can splice into this. Who cares how much current it uses.
Spliced into the dimmer module.
Awesome tag along with the connectors that weren't crimped correctly. This was like this on just about every wire for the stereo.
This is one of the big cluster$%^*s. A hot and ground were just dangling under the center console without any covering. One of the center console aux power outlets was spliced into the wire that was spliced into the connection in the fuse box (pictured above).
