I weighed some parts over the course of time. Thought I would share. These are off a Ty. If you got more just respond. This should be a good archive thread.
Stock Fog Lights (Pair) 3.50 lbs
Suspension Techn rear sway bar with hardware 19.25 lbs
Vacuum Ball 0.81 lbs
Cruise control actuator with bracket 2.13 lbs
EGR valve 0.81 lbs
EGR solenoid 0.44 lbs
Rear window wiper motor assy with wiper 3.94 lbs
Roof Rack 9.69 lbs
Rear air shock compressor assy 8.44 lbs
Rear air shock level actuator 2.19 lbs
Underhood light 0.25 lbs
Boost solenoid 0.31 lbs
Stock water pump 11.75 lbs
Alum water pump 7.5 lbs
Relocate the ECM to the glove box and save a pound:
ECM bracket 0.88 lbs
Rear glove box cover 0.13 lbs
Save some weight for the track? Here's 53 lbs you can shed in 10 minutes!
Stock front floor mats (Pair) 5.38 lbs
Stock rear floor mats (Pair) 2.06 lbs
Spare tire hook + wing nut 1.25 lbs
Spare tire with cover > 33 lbs
Tire jack L bracket + wing nut 1.25 lbs
Tire jack 8.5 lbs
Lug wrench 1.56 lbs
Don't ask for other weights. I am not pulling parts just to weigh them.
EGR valve 0.81 lbs
Roof Rack 9.69 lbs
Tire jack 8.5 lbs
Lug wrench 1.56 lbs
