Timing curves???
turbosonoma
i know the timing is supposed to be set at 0 degrees with the tan wire unplugged, but i have dfi so my truck needs to be tuned from the beggining, nothing is in the ballpark of where it should be, my truck is quite un stock, so i was wondering if anybody has any timing maps that they would share to get this heap running properly. Also i was wondering what exactly effects the timing curve of one vehicle to another which may be modified etc...
thanks in advance.
jwaller
Evil Genius/SyTy Guru
Re: Timing curves???
Im sure there are many out there but with no details on build or ecm. we cant help you
turbosonoma
ok i guess that is all important then
its a 4.3
50#injectors
commander 950 dfi
precision gt 67 turbo
vortec heads
412-8 comp cam
srp piston
eagle h beam rods
air-air
3000 stall
2wd
is that enough?
jwaller
ya thats a good start. I can email you a few curves when I get home friday. I dont know many ppl running that box so it will have to be a screenshot of either a fast program or a stock ecm setup but it will have all the info you need.
