lewisstraughn
Lewis Straughn
I went out to start my Ty this afternoon and it just turns over and nothing. I did the test where you connect a test light on the fuel pump test lead by the fuel pump relay on the fire wall and it lights for 2 secs when you turn the key to the on position. I put a fuel pressure gauge on the shrader valve and turn it over and no pressure. How can I tell if the pump is working without removing the tank? Where is the fuel pump fuse located? I've looked everywhere and can't find it. What else should I check?
Thanks for any tips,
