Turbo drain hose
nastety92
I'm looking for a oil drain hose from the turbo to the oil pan. Please let me know if you have one available for sale, I'm in need of one ASAP.
Thanks,
Nick
Baythan
SY2TY2SY2TY
Re: Turbo drain hose
RPM sells them. About $85, braided. Nice piece.
edit: or used to. I don't see it on the website. :dunno:
TYHOGG
if you need just the hose go to the auto parts store grab a piece and two screw clamps
nastety92
Thanks for the tip but I'm missing the whole piece, hose and connectors.
RPM does still sell this piece but I'm trying to find another solution other than spending $85. I'm not sure how long this motor is going to be in this truck.
Thanks,
Nick
TYHOGG
Sorry didn't realize your missing the whole thing. I'll check to see if I have another one laying around.
Slyclone
Well-known member
Good morning, I messaged You in regards to the turbo drain to oil pan. I have one which is a stock part. I offered to You before. Never heard anything. Are You looking for OEM or a braided stainless part?
This is what I have
nastety92
Sorry about missing that P.M. Just sent you a message.
Thanks,
Nick
crariley
The RPM braided stainless steel hose is a PITA to work with for stock turbos. It didn't come with a gasket for the turbo side so I had to buy gasket material to make a new one. Also the aluminum piece used to connect the turbo to the hose was too thick to use the stock bolts. So I had to cut it in half to make it thinner. Knowing what I know now I would've just replaced the short piece of hose that connects the oil pan to the drain pipe. That was an $85 lesson learned.
