Turbo upgrade question
Ls10
My new build will be forged bottom, vortecs,atr headers,alky,custom cam,3k stall with built trans,RPM front mount, ported lower intake,52mm TB, roller rockers, 60# injectors, might be missing a few things. I have the option of a 62mm or 67mm turbo. Both .82 exhaust side. Both billet wheels. What one would you guys recommend?
Static
Re: Turbo upgrade question
67mm You have all the mods to support it. Rode in a truck recently that had a 70mm with similar mods.
Ls10
Ac is already gone. Just didn't know if the 67 would be too big and I'd make more power and drivability with the 62
Slyclone
Well-known member
From what I remember you have to remove it.
I ran a 61mm and ac was intact. I currently have a 62 but never fit it up. I would think its similar. The compressor housing on the 67 is just BIG.
randy merritt
I am currently running a ball bearing 63 and love it. Spools very fast and has plenty of grunt for the street. I still have A/C. I briefly ran a ball bearing 72 (about one day), but it had way to much lag for my 2800 stall, and I put the 63 back in. I couldn't build any (zero) boost for a boost launch, and the turbo didn't spool until I hit second gear. The 72 did clear the A/C with a small spacer between the exhaust manifold and turbo. The installed 72 is shown in the picture.
Ls10
I figured with the light billet wheels, and the .82 turbine housing I don't think spool will be a huge issue. I have a .89 with a 54mm now and it spools very fast
Aeroking
e.i.
this is the PTE 72mm i used to have on my truck. I had an AC delete pulley, and it cleared the pulley and accessory bracket.
Remember, most people who use PTE turbos, are using the SyTy turbine housing (.85ar). Which is made to fit the trucks. If you are going to use a 3-bolt GN turbo with an adapter, or a T4 with an adapter. That is going to move the turbo around. Also headers, instead of stock manifolds will move the turbo around.
Ls10
I have a custom 3 inch downpipe with vbands. So the housing is not an issue. It should mate right up from my old turbo
Personally, I would probably do the 62mm.
The 67mm has the potential for 700+ hp at high boost levels. A 62 has the potential for well past 600 maybe 650hp. I am guess your built transmission isn't a 4L80e either. You probably don't have enough injector for a 67mm pushing high boost either. On the flip side you could go with 67 and have some head room if you wasn't to go faster later.
Ls10
Yeah still 700r4. And that's what I'm thinking. I'll have this truck for a long time. Eventually 4l80e and Holley with bigger fuel system. At least I won't have to worry about getting another turbskie lol
syclone3
I bought a new PTE 6776. But I have headers on that truck. Maybe give me more clearance with the AC.
Ls10
I have atr headers,and no AC or ac bracket so size isn't much of an issue
Ls10
So does anyone think I'll be slower or lose power with the 67 over the 62?
Sean Krupa
Moderator
Just run either Turbo! Goin from a 62 to a 67 is maginal. I went from a 63 to a 72 and didn't hardly notice a difference in Spool up. All in the Tune and Converter.
Ls10
thanks sean. ill just go 67 for future. even if it hurts me over the 62 like you said. it will me so small I wont notice. especially since im not looking to break any records hahaha
