Turbotime Rear Coilover Preload
I am installing my turbotime rear shock/coilovers on my Syclone. How much of prelaod has everyone used. I am just trying to get an idea to get me start in the right direction. I have Belltech lowering springs as well.
Daryl H
Re: Turbotime Rear Coilover Preload
Put the truck on the ground and pre-load them to where the truck stance looks good.
Drive around and check again. Done.
Its kind of hard to do that without an engine in the truck :)
E-Rue
you need to start by putting just enough preload for the spring to fit tight with the suspension at full droop. start there and increase it as needed to get the ride your looking for. you probably wont adjust it much from there if at all.
e
