Turning off Leveling System.
Logic
Hey guys,
Is there any way to turn off the air compressor for the automatic leveling system? Is there a fuse in the fuse box that I can pull in order to turn off the compressor?
Are there any downfalls to driving without the compressor on?
Thanks,
Eddie.
ItsMyTy
Life is beter at 25 PSI
unplug the fuse, i think it's the ELC fuse.
no downfalls except you'll notice the ass end sit lower when you load it down... or even when u fill up the gas.
i ripped my ELC stuff off last year when the sensor cut thru my LR abs harness during a launch. it didnt work anyway.
GM TURBO
Sell Out
If you still have the air shocks I would recommend replacing them. I pulled my fuse and shortly after the shocks started losing air. It could have been a prior condition. The air shocks suck anyway.
Logic
Let me get this straight...
Okay, so I pull out the ELC fuse... that's in the fuse box right? Is it labeled? I'd go check myself, but it's ten degrees outside right now. Your answers are keeping me nice and warm by my computer :D
Thanks guys,
Eddie.
BigBadSmoosh
very bottom fuse in the fuseblock..
mine is out, the assend is a little high.. but no pump :D
