Typhoon #1936
Typhoon#1936
Standby to Standby
Bought one of my dream cars the other day, needs TLC..
Engine Bay, wanting to put A/C back in it (have all parts)
And rebuild Spec sheet..
So i have some questions since i'm new to the typhoon game..
I need bigger injectors, 3 bar map, a tune, window motors (or switch?), lock cylinder for rear gate. plan on getting motors/switch from pick n pull and the lock cylinder online. how hard is it to put the new lock cylinder (for the gate) in? also i want to hook up the rear glass popper, pulled the bezel and its unhooked.. cant find connector, not sure if poppers are even there..
how about getting a/c back? looks cramped but i think a new pipe from turbo to intercooler would be needed..
also when warmed up and i go to turn it back on, it turns over slow.. im assuming that this is starter wire being too hot, needs insulated?
these trucks came with remote locks, right? how would i get those back? and remote start? lol
also, until after my gatlinburg trip im on a tighter budget. on the fence about getting moates ostrich, code 59 with autotune, etc. just need ideas and a little help is all.
Typhoon#1936
Standby to Standby
Re: Typhoon #1936
Update: power windows work, needed a switch. Speedo works, DRAC wire was loose. Fixed the rear lock cylinder. Purple wire needs addressed and so does cruise, i hooked it all up but nothing. no light on the dash or response. what to check?
Also i put a factory radio in it. i need speakers (missing) and mounts for the radio, its just sitting there currently.
