spikestingray
I was just wondering where you guys that are located in Ontario, Canada are buying parts for your engines. I just purchased an 88' Blazer dressed as a Typhoon with a 92' Ty drivetrain, (some of you up around Barrie may have seen it as that is the area I bought it from) and I'm planning on using the engine to put in my 95' S10 Blazer 2dr, 2wd. I had to pull the fuel rail off as the port that a fuel pressure gauge would screw on to broke off. In order to do so, I had to pull the upper intake plenum off and now I'm looking for the plenum gasket, throttle body gasket and injector 'O' rings. I have called the local GM dealer and he says the intake gasket is discountinued and I have tried Napa which they said the same thing. I'm just wondering if you guys deal locally when getting engine parts or if you just order parts over the net and have them shipped cross border? Any help in this matter would be great.
