Where to rerun tranny lines
Syclone Rob
Its all ABOOT the SYTY eh
Hello all, I am going to start rerunning my tranny lines with briaded lines. To those that have done this, how did you route the lines? I plan to remove the stock hard lines. Pictures would be a plus.
Thanks all,
Rob:tup:
SY2932
Administrator
Re: Where to rerun tranny lines
From the vault:
Syclone Rob
Sorry Mike, I should be more clear. I know the order of hook up but how did you guys that have done this mod run the lines from the tranny.. The stock hard lines run near the downpipe and comes up hear the crank pulley and lower rad hose. Since I want to replace it with braided lines, I don't know which way to run it.... Any ideas?
Black Knight
I Glow Therefore I am
Are you going to run the cooler back up front or try and keep everything under the bed?
Ryda85
Senior Member
i am going to run everything back under the bed with a fan
Syclone Rob
I want to run it to the front, that way there is always air passing thru the cooler...
SY2932
Administrator
I know that mrweelr has done this mod. Perhaps he can enlighten everyone. I imagine that the lines are secured to the frame along the run.
cloneman315
u can just lay them on the trans and tie them with wraps thats how i did mine,just make sure u put the end on the trans and screw the lines in be4 u put the trans back up in it is really tight i ran a big cooler up front and it works perfect,my pics are on the site in the pic section i believe,if this helps
leroy
I ran mine through the frame....had to drill a couple of holes, and put grommets in.
Jim
jjorgensen52
NHSTE - I'm the only one!
Mine run right on top of the frame rail and around the back of the shock mount. They are hard lines so I didn't have to clamp, but that was the most out of the way place I could find without going through the frame. I do have a front mounted tranny cooler
