wieseco forged pistons
littlety
I am in the process of doing a build on a ty engine and it was recommended to me to try ou the wieseco piston. Reason being is that the dish is deeper thus icreasing the compression to 9.1 to 1 instead of 8.5 to 1. This allows the turbo to spool up more quickr and also makes the engine more reliable and run better more smoother .
Any comments?
Or suggestions?
thanks,
jim
ghettosled
SYTY SUPERSTORE
Re: wieseco forged pistons
a deeper dish will yield a lower compression, not higher..
A higher compression will yield a crisper throttle response, and make more power however there is a limit to how much boost you can run with increased static compresion and lower octane (ie 91/93).
8.5 - 9:1 is common but make sure to measure your cylinder head cc, deck height, gasket thickness etc before you order pistons that will raise your compression even higher.
littlety
So Mike what do you recommend....My chioce is to stick with what i know and what i know is....je/spr or trw pistons...
your suggestion?
thanks.
jim
James Thomas
"NO CLASS"
Go the 9:1's on a street / mid high performance build. You'll like it.
___________
James
ghettosled
SYTY SUPERSTORE
Wiesco, JE, Ross, CP all make nice pistons with various specs. TRW is a heavier cast piston , which is a step below the previously mentioned brands.
