Wipers with a mind of their own
5SpdTy
some wierd stuff. ill just be driving down the road and occasionally ( once ever two weeks or so) the front wipers will turn on, go up then down and thats it. and doesnt happen all the time, just pretty much whenever they want to:). any thoughts? it doesnt bother me, it doesnt hurt anything(i dont think so anyway:D ) , just wondering if anyone else has this weird problem.
Jimmy
Banned
Re: Wipers with a mind of their own
Mine come on every once in a while when I switch the turn signals on :dunno:
syclone0577
My dad had a 90' S-10 that did the same thing. must be a GM trait.
cloneman315
the ground breaks down in the combination switches and the ground is weak and thats why they come on ,on the newer s10s u will hear the relay clicking under the dash
psmvchaser
Yeah....I heard you have to remove the steering wheel to fix it? PITA.
I just pulled the wiper fuse....I don't drive it in the rain anyways and you could always pop it back in if you need it.
Loeryder
Syclone Rob said:
ahh yes...... the phantom wipe...... its an s10 trait....
Yup, its a well known phenomenom.
I believe it is the contacts in the wiper stalk switch.
Replacement involves breaking down the entire column.
Mine does it and I just laugh. Got bigger fish to fry I guess.
One of those "while I'm in there mods" I'll do with a MoMo wheel and steadfast steel colum collar.
kentuc
No need to do a complete column breakdown to fix.Just use a new stalk,{the handle only}.It pulls straight out.The only wires are for the cruise control.Below the column disconnect the cruise wire harness. They are three very thin ones. Attach a thin piece of wire to the end of the harness that goes back into the column, and pull the switch handle away and out of the column until the attached wire appears from the hole of the turn switch. Attach the new cruise wire to the tracer wire and pull back down through the column. Snap the new handle in place hook up the cruise wire. Done. I have done this many times. It really pays when you flat rate!
cloneman315
that only replaces the stalk not the switch,and yeah on the older s10s it is a pin in the ass
5SpdTy
wow i didnt know it was so popular:rotf: . yea i dont really care bout it either, it is kinda funny, no need to fix it, it gives the truck character:tup: .
turbodog
kentuc said:
The problem is the switch in the stalk.
Huh? The only switch in the stalk is the cruise control switch. Are you sure changing that will fix the 'phantom wipes'?
That would be great news. I replaced the wiper switch (the one inside the column) and it did NOT fix my phantom wipe problem. Can you explain how the cruise switch affects the wipers? Inquiring minds want to know.....!
Jer
Don't taze me bro!
When I first bought my Typhoon it did the wiper thing pretty often when I turned on a turn signal. I noticed a while ago that it hasn't done it in quite a while and I didn't fix anything involving the arm. Weird.
InvisiBill
Isn't the physical switch for the wiper delay in the stalk too? I have considered that if it were loose, the delay pot could be shorting out (especially when you push on the stalk for the turn signal), turning the wipers on. I've been hearing about the switch in the column for a long time, but some random instinct still makes me think it could be the stalk itself, especially if it's when you're putting pressure on the stalk.
5SpdTy
well i guess if it starts happening more often then ill fix it, but right now its all good
cloneman315
no grab the switch and yank it it will come out and u will see how it works ,it has a lil slot that brabs the swtich in the colum
blk00z28
Forced to by choice
Add mine to the list here. But it started doing it only after I replaced the wiper motor. :roll:
Ontop of that, mine stop where even they choose to. If I do the "mist" thing and dont hold it down, they will stop where ever I let off the switch. Would this fix that as well?
hatrik8
Add another truck to the list of turn signal wiper activation. HA
