Re: Worst case scenario...
Some of the more common problems are:
-heater core leakage
-engine problems (ignition, ic pump, bent rods/pistons)
-transmission failures,
-bent wheels, steering issues, crossmember damages, motor mount breakage
-alignment issues, wandering
-turbo boost adjustment, wastegate issues
-fuel pressure/fuel pump, fuel filter issues
-heat soaking, high IAT or MAT temps
-Cladding damage
-propshaft issues
-bouncing Typhoon rear seat, rear wiper and/or rear window leakage/squeaking
-failing state emmissions with clogged/missing cat
-broken/cracked exhaust manifolds
-and if your SyTy is lowered, you may have load leveler, bounce stop, non-centered rear wheels,
or short turning radius/rubbing
Some folks even have overboost or noise issues inside their vehicles (like a Typhoon
that reverb`s sound noise) when they delete cats.
Larry
