Re: Yes i know..another low boost question....UPDATE!!!
I installed a new solenoid today and tried that, no difference. Then i searched and found a pic of the lines attached to it (solenoid) and mine were different-opposite of the pic. I changed them around and again no difference. (can someone post a pic or tell me the correct placement for these lines just in case the photo i went by was wrong) I then searched and learned that with the key on the orange wire going to the solenoid should have 12 volts, mine does. Should the black wire be a ground and how do i check it? I also tried to move my waste gate rod and it won't move, it seems as though it's seized. Is this normal?
