phoonTy
Truckless. For now.
Since I'm really trying to make my truck a weekend cruiser instead of a daily driver, I've decided to pull the A/C to clean up the engine bay, and my blower motor didn't work for about a year (until I finally found the loose ground) so I got used to not having it.
Long story short, I have everything loosened at the firewall, the A/C box is loose etc. By loosening the rest at the radiator side, I should be able to pull everything out as one unit, correct? On the radiator side, there's just a small cooler held in by a restraining strap, correct? Anything else I need to watch for, loosen, etc. to get it out easily?
Thanks for the help! :tup:
oh, one more question, the lines running under the box, but not into the box, into the cabin are the coolent lines into the heater core correct? they run through a hole in the box and i'd rather not cut it, incase i fell like returning everything to stock and having it look untouched. :tup:
now, thanks for the help. :lol: :tup:
