Ok where do i start , when accelerating (pretty hard) and is about to change to second gear the engine stumbles and looses power and hangs on to first gear like it doesn`t whant to change gear ?
Work done so far
It throwed code 45 ,Put in i IAC valve today and that fixed my ruff idle and no more code 45 , put then i throwed code 42 instead
I am running stock chip , 32lbs injectors (brand new) , and had some work done on the heads
i also have set base ignition today
brand new plugs and intake gaskets
What the He** is going on ? solutions ?
Work done so far
