LS powered SyTys
MikeRenz
not stock
I'm curious how many there are floating around now, and their setups.
Syclones:
  • Syclone0565: S400 LS1, HP Tuners....parted out
  • TryMe: Single Turbo LSx, XFi
  • Turrrbo6: n/a (for now) LS2,
  • Vengeance Racing: LS2,
  • eviltwin: tc78 LSx
Typhoons:
  • MikeRenz: Green/Gray, Twin Turbo LS1, Big Stuff 3 (Former CJSTyphoon Truck)
  • danimal95: Green/Gray, Twin GT35r LS1, ____
  • PPI Typhoon: Black/Black, S400 LS1, being built
  • Nick Steffens: Blue/Blue, Single Turbo LS6, being built (Former Todd Dearborn Truck)
  • ??????: ?????, N/A LSx in Montreal
  • sparkwire, pt76gts LSx,
Hopefuls/Future:
  • SkwayB: Typhoon
  • NecroWolf: Syclone
who else. I wouldn't mind having a master list.
jasonpickett
Re: LS powered SyTys
I will be working on mine soon.
Mike, syclone 0565 didn't have xfi. He used HP Tuners with a aem injector controller.
powercat6
Syclones:
Typhoons:
PPI Typhoon: Black/Black, Single Turbo LS1, being built
What about Jeff Scott's?
skwayb
NWSTP
I'll eventually have my White 93 on that list that I am giving to my wife. She like to use the peddle so anything more reliable than a turbo'd V6 is the way to go :-b
bdydrpds10
Yes I drive a Typhoon.
There is the Syclone Vengence Racing in Atl Ga. swapped a ls2 in.
I don't know if the owner is an active member of the forum or not.
turrrbo6
#1699 LS2 n/a for now. Hope to fire it up this weekend, just got my custom harness from Current Performance this week. Engine harness plugs directly into the Syclone firewall connector. Will retain factory gauges, cruise, and a/c.
MikeRenz
not stock
ah yes, how could i forget about #1699. That thing is a beaut! Hurry up and finish it so you can bring it to NATS! :)
s_blazin
damn those valve covers look badass
There's a LS1 Sy in Saudi Arabia and then there's Bruce in TX doing a 6.0L...and 95xtreme.
Where in Saudi Arabia? Got my Ty from the GM dealer in Al Khobar in 1992 and never saw anyone else out there with one. Black trucks in the middle east :rotf:
RAACCR
SY #2648 is probably about a month away from final mock-up. 408" all-aluminum LS2, Callies crank, Compstar rods, Diamond pistons, HIP'd Pro-Port Edelbrock heads, CNC'd to 245cc by Richard @ WCCH. Twin Turbonetics 76mm turbos. 160# injectors fired by Megasquirt on E85. CK 4L80e transmission (every possible upgrade except trans brake). Circle D converter (thanks Chris). George Blake Typhoon transfer case (billet input and planetary). Mike Lee's LS swap parts. Race Parts Solutions and Jake are helping with misc. parts & fabrication. Coilover front suspension, (thanks Jax) big brakes, yada yada yada. Not expecting much more than 1000awhp with the current hand-me-down motor, but already have a much more serious bullet in the works.
jpalmer
geez, makes my build sound stock. cant wait to see all these builds in mobile form.
The Saudi Sy runs. So does the one done by Vengeance Racing.
edit: here's a KB sc'ed 6.0L done by beyond-redline
http://www.syty.net/forums/showthread.php?t=63253&highlight=lsx
Project: Build Typhoon with LSX motor, Retain stock appearance, inner fender wells, AWD, Daily Durability.
Big thanks to syty.net and all that have helped with our latest build. Here are some pics below.
Here are the Mods:
408 Engine using 6.0 L LQ4 Iron Truck Block, Callies Crank, Carillo Rods, Diamond Pistons, LS6 Cylinder Heads, LS2 Front Dress From the C5 corvette. Custom 8" Crank Pulley and 8 Rib Setup. Kenne Bell 2.8H Intercooled Currently Running 13Lbs of Boost. 2004 2500 Chev Truck PCM, Speartech wiring harness, 60lb Injectors, 4L80e with George Blake Conversion Parts, Custom Rear Drive Shaft, George Blake Front Shaft. We built the Custom Stainless Long tube Headers and 304 Exhaust. Moser 12 bolt rear and custom wilwood rear discs.
I don't have a copy of the time slip, but the truck went 11.4 @ 121 w/ a 1.78 60 foot. (spins a lot :lol:) truck is still full weight (4280lbs with me in it)
I know there is a ton more I can post, but i don't want this initial post to get too long winded. If you guys have any specific Questions or would like to know more specific information reply. I am sure i would be able to help out the community.
Thanks for All the Help syty community.
Luke @ Beyond Redline Performance
edit: It looks like E-Rue was working on one a while back. I wonder what happened with that.
