slpcamaross97
If anyone of you know me i have nothing but BS stuff going on with this SY of mine.
The mods include.
L35s
AFPR
Manual boost controller(set on lowest setting)
3 Bar MAP
1.6 RR
exhaust with no cat
custom chip from Noslow50. Chip is made for 18-20 PSI boost and 45 psi fuel pressure(at idle), EGR delete, 3 bar map and fuel tables set for L35s.
So my problem is i have a detnation problem when boost pressure is over 8 PSI. Can hear the truck buck and pop through the exhaust.
Now Fuel pressure during the concern is 55-60 PSI
boost is 7-8 PSI
Base timing is set at ZERO(with brown wire disconnected under dash, engine at idle)
At idle timing sits about 3 degrees
Fuel is new 93 oct.
anyone have any ideas?
The mods include.
L35s
AFPR
3 Bar MAP
1.6 RR
exhaust with no cat
boost is 7-8 PSI
Fuel is new 93 oct.
