Quote:
No, but he's using better heads than your ????? heads... in fact he's using !!!!!!! heads. I think he's sold some && mm turbos to other people as well
I am using the same pontiac heads, what am i a moron spending 15k on a whole setup that is gonna blow, u think yes, oh well, and im running an 80mm ball bearing turbo!! plus i am going to have the same intake and throttle body!
Quote:
You talk about doubting a turbo system that hasn't run the number, yet brag about your system that is still in the planning stages?
Well i guess u know more about my truck than me, planning huh, what???
I guess I assumed you were still planning since you used symbols instead of actualy buildup nomenclature. Am I to assume you are installing this motor in Merk's truck, or yours? Am I also assuming you have a grasp of the English language also? Combined with your combative tone, it's pretty annoying.
Tell Mike you need bigger than 50# injectors, like 83#. 80mm turbo... So I'm assuming you are doing a fuel cell, Weldon pump, Bowtie oddfire motor, and going RWD? I've been down this modification road, and was just maybe going to give you some insight, but since you know it all... I'm sure you'll just be able to enlighten the rest of us..
