roll call for sucessful meth users
blk00z28
Forced to by choice
Re: roll call for sucessful meth users
I use the SMC kit. Came with the truck and it works fine for me.
10secTy
Sy-Ty builder and Tuner
When using the alkycontrol systems and running 100% meth I have set up trucks to run 28psi with 28 degrees of timing with zero knock. If you mix water and meth it will be less.
Nolan
jjorgensen52
NHSTE - I'm the only one!
I knew what this thread was about, but I still couldn't help laughing at the title.
I haven't used alky yet but I'm thinking about it
I have alky control, but I never dialed it in. I was have other engine/tune issues.
2kwik4u
Resident slow guy
Jeremy uses AlkyControl system. Daron uses SMC. Hardman has one from Devils Own (I think thats right). I've read of several others using the Snow performance setup. I think any of them will do the job just fine.
Flyin Ryan
hated cuz he drives fords
I had the alkycontrol kit but ended up selling it and later on buying a devils own progressive but haven't had time or a chance to even begin to use it and tune etc
Don W.
I have Alky Control. The system works well. Tuning, which I have to do, is a different issue.:rotf: However I'm very close. Engine is very sensitive to small changes. Finding the right combination of fuel pressure and meth can be interesting.
nallj92
homemade kit, 25psi 21 deg timing, no knock, run straight meth or sometimes high octane washer fluid
shoebox1.1
do you think MOST people run straight methanol or washer fluid which is approx 60-40 water? the 100%meth has the octane and mixed water would have better heat dissipation is that right? im planning on building my own kit with a shurflo pump. the devils own kit has a really nice brass hobbes switch that has engraved settings where most are plastic and your guessing when the spray comes on at.
skwayb
NWSTP
Both work but Methonal evaporates at a much faster rate than water so it will have more of a cooling effect. All I know at that start of a run My MAT is 100 at the end it is at 70 with Methanol. With Water it was in the 90-95 degree range at the end and I couldn't run as much timing.
This says it all.
Nolan
I would listen to Nolan. He knows his stuff.
MYYellowTY
Ive been on Methadone for 9 years now.Ever since May of 99 ,I was run of the road and into a chain link fence at 60 and lost all movement and feeling in my left arm.The Meth takes the edge of the Phantom arm pain.And the Percocet does NOTHING AT ALL!!!
OHHHH, you ment Methanol.Sorry never mind!!! :rotf: :rotf:
juicehead9
93 Typhoon # 0973
I ues devils own progressive 100% Meth so fas so good, even better temps with A/A
Six-is-Enough
Use to do a little Boost
This says it all.
X2. Razor's alky control. 100% straight VP Fuels Methanol. I have ran 24 psi, with 27 degrees of total timing on 93 octane pump gas. 0 knock:D .
MIGHTYMOUSE
Turbo F body guy
this 20+ boost and 20+ timing with meth is on 93 octane gasoline base correct?
shoebox1.1
how much is the methanol per gallon and how much do you buy? fill up a 5gal jug and store it? intercooled and straight meth AND a carburetor.... i think 10 psi is do able even with my 10.8 cr er hopefully! :)
blk00z28
Forced to by choice
The price depends on where you live, and if and how you can get it. I'm limited to butting Heet at the local auto stores. Which gets $$ the more you use.. The local oil place used to sell 55 gal drums of it for $145. I wish I would have bought one or two before they shut down..
12secondSY
Syty Killer :(
Wow, reading about all this boost with zero knock makes me want to go outside and tune my truck better. Im still at 14 psi with my alkycontrol kit unhooked and my truck runs pretty damn good. Im sure I got another 100hp in it just waiting to be used. :tup:
