Six-is-Enough
Use to do a little Boost
Re: roll call for sucessful meth users
I get mine from the local speed shop. $3.25/gal last time I bought it. Usually get 5 gal a trip. 15 gallons or so holds me for the year.:tup:
Most of your drag strips sell methanol, or speed shops or racing karts shops. You might also check with your alky kit supplier about using E85. This might be a viable option and more readily available.
Also be careful about using low (cheap) grade methanol. A local speed shop showed me a dyno graph from a drag race engine running VP fuels methanol and then switching to a low grade industrial use methanol and there was over a 30 hp diffrence.
shoebox1.1 said:how much is the methanol per gallon and how much do you buy? fill up a 5gal jug and store it? intercooled and straight meth AND a carburetor.... i think 10 psi is do able even with my 10.8 cr er hopefully!![]()
