Finally have a mold for making urethane cladding
PPI Typhoon
DIY Madman
Just pulled the mold this afternoon. I have some cleaning to do on it, but I figured I would post some teaser shots.
I'll post more about it later. Have some things to do this evening.
warmpancakes
Re: Finally have a mold for making plastic cladding
thats makes my pants happy
Kybol
I bet it makes most people's everything happy, including their pants.
live1053rulz
Nor Cal SyTy
You're awesome.
DynaGlide
Ton-Eighty
Schweet
BigBadSmoosh
good work.
QUICK STORM
B.A.M.F. BMW Tech
nice, you would be on awesome help to people with broken cladding
Flyin Ryan
hated cuz he drives fords
wow man glad to see your making head way.. hows about some cf doors/fenders :)
J_SULLIVAN
A&P slave monkey
Looks good. :tup: How close are you to finality?
PPI Typhoon
DIY Madman
Made my pants happy too when I pulled it this afternoon and had no blemishes. :tup:
Stangbeater
How bout it?
looks great. Can't wait to see the final product.
PPI Typhoon
DIY Madman
Well CF is possible. I have made a mold for making fiberglass, but since that was already done, I went a different route to make a mold for urethane cladding. Believe it or not, they are 2 completely different setups.
However since I started doing the fiberglass setup for doing vacuum infusion (the only way to go for making fiberglass and CF parts), I have all the equipment needed to make a CF/fiberglass piece. :cool:
PPI Typhoon
DIY Madman
Pretty close. I work on it for a few hours every day after work. I just need to work on a few things with viscosities of the materials and flow patterns, but once that's ironed out, I'll pull a part from it.
Hopefully within a week I'll have a master mass part (solid piece, not a thin-wall), and once I have a master piece, then I can focus on making actual pieces. This is important because I don't want to keep using my original cladding for experimentation. It does take it's toll on the pieces. :rant:
93TyGuy
Boost Freak
Bad Ass!! :boink:
the baPhoon
you sir, are a gentleman and a scholar. If i tear my stuff up i know whos door im gona be at :)
berzerker
wookie
will you have front bumper covers availible. and if so .. what will be the going $$$
PPI Typhoon
DIY Madman
The plan is to offer all pieces. The bumper will be the last piece I mold as it will be the hardest and most expensive piece.
Going price I plan to be around $250 maybe for a front bumper. I have to calculate the material costs though, so don't quote me on that. It very well might be cheaper than that.
As stated before, it will be less expensive than buying Ebay cladding and fiberglass replicas. If I can't bring it to market for less money, then I won't bring it to market. :)
V895
All Moter Whore
Sweet A1 job.
Andreas
I'm incredible impressed.
Thats just awesome!!!
CarbonFiber AWD
Correct me If I'm wrong here but, isn't that a simple poured latex/silicone flexible female mold pictured there ?
An infusable mold requires a considerable outside flange and that one has none to speak of. Not to mention that to make a good ,well held shaped part in composites requires ZERO flexing during dry layups, prior to prevac and infusion ,particularly with some of our more complex cladding pieces.
Even if you were to go another step and make a solid Master and lay-up for a Male mold you'd be going the wrong direction.
I don't want to come across condecending here, Its just that I do alot of CF VIP or Infusion and the processes are indeed much more complex than I see in your effort there.
The biggest concern once proper molds are made too is the final close tolerence body fitment. These parts can only fit as good as the parts they are pulled from. Warpage is almost a certainty when a loose part is not mounted or jigged to a parent surface to remain tight. Blah , blah, blah .....I realize how this comes across. I just didn't want anyones hopes disoriented, perhaps even your own ?
Now if your going for a sprayed Eurothane/ Carbon plastic and can control the build thickness with some nice expensive two-part equipment.......then your mold may work .
Best of luck ! :tup:
.............V'
