Tell me I am not stupid.
I got the fresh 18* oddfire v6 and this junk syclone and I want to put them two together.
The V6 got an oddfire distributor and oddfire msd 6t box. Its 12 -1 compression, if convert to wet sump it should ready to run.
I am thinking to change the head gasket and bring it down to 11-1, not sure how much boost can run on this compression.
The other option is to go efi, I have a BS3 which can be convert to oddfire but I will need " an even fire crank trigger wheel with 2 wire pickup and a hall effect cam signal" which I can't find any info on.
