Here we go..
SYCLONE
readjust swaybar
fix broken ball joint
replace front tires
alignment
new shocks
install blitz SBCid2
install exhaust pipe extension
fix altessa light
fix license plate light housings
driver side window motor
replace broken headlight
replace driver door hinges
install air intake
relocate battery
fix headliner
change xfer case fluid
fix spindle carrier bolt hole
remove / reinstall trans (getting built)
plumb new trans lines
install trans cooler
take out cyberdyne gauges
reinstall autometer guages
ignition tuneup
misc. powdercoating engine parts
new upper intake gaskets
fix wiper squirter
readjust fucking fiberglass hood
repaint ENTIRE truck
install 50# injectors
install Ultimate Chip
make custom brakets for gauges, etc
install Hayden Cooler
install A2A? might have soon?
install propshaft loop
TYPHOON
2 new tires
alignment
replace knock sensor
ignition tuneup
front shocks
fix / replace foglights
rear wiper switch
BOTH window motors
replace door hinges both sides
replace AC Delco Radio with CD unit, and all speakers
install cyberdynes that came outta the sy
install BOV off the sy
change xfer / trans / diff fluid
repaint cladding
finish fixing cancer spot on rear pillar
clean engine bay, misc powdercoating
after reading all that..... i should beat myself. The typhoon is excused, cause its still relatively new. The sy's crap has just been building up with no time to work on it...though, its going down very shorty for the trans overhaul and all the other junk listed that needs to be fixed.
my sy stays at my parents house, 100 miles from where i live.... me and rox daily the ty, so its getting some good mileage on it..... which is fine, cause thats what its made for. im lucky to drive the sy on weekends.....
